Problems cutting the radio bezel
Old 12-29-2002, 02:55 PM
scottw
scottw's Avatar
Default Problems cutting the radio bezel
I am putting in a new radio and have to cut the bezel. I bought a carbine steel cutting blade for my dremel but it won't cut it. What is the easiest way you guys have cut it?
Old 12-29-2002, 03:04 PM
Smokehouse69
Smokehouse69's Avatar
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Problems cutting the radio bezel (scottw)
I haven't tried to cut my bezel, but I've always had very good luck using the little cutting wheels that come in the tube. I've used them for cutting everything from stainless steel to ceramic tile. They work great on all kinds of metal, but not worth a damned on ceramics. The carbide wheel I bought was great on ceramics but didn't cut worth a damned on on metal of anykind.
So, I'd suggest using the little disposable wheels, you'll go through a bunch of them, but they are fairly cheap and they will cut.
Old 12-29-2002, 03:07 PM
Love My 72 and 77
Love My 72 and 77's Avatar
Dremels are for fingernails you better use a die grinder. Use masking tape to give yourself some kind of an outline and cut that sucker. although my real opinion is -DONT CUT THAT! those bezels are fairly expensive and actually still available from GM (with a vin#) but I like the stock look. Good luck :smash:
Old 12-29-2002, 03:13 PM
Clink69
Clink69's Avatar
Don't cut it ! Buy an already cut one from someone...
:flag
Old 12-29-2002, 04:15 PM
Bobchad
Bobchad's Avatar
Cut it with a pair of tile nippers. Cuts straight with no problems. My dremel generated heat on the plastic and made it soft.
Old 12-29-2002, 05:18 PM
Titanium Rat
Titanium Rat's Avatar
Default Re: Problems cutting the radio bezel (Bobchad)
his is metal
To Problems cutting the radio bezel
Quick Reply: Problems cutting the radio bezel
