New differential drain plug kit for '63-'79 vettes.......
There is now kit available that allows you to add a drain plug to your '63-'79 vette's differential, making changing your fluid a whole lot easier. That kit includes everything you need for the job, including the drill bits and thread tap. I'm NOT affiliated with Corvette Clinic in anyway, I just read the article in Corvette Fever.
The kit is available from:
Corvette Clinic
Dept. CF
701-D Cornwall Rd.
Sanford, Fl
32773
phone # is (407) 323-0128
Or online at http://www.corvetteclinicinc.com
[Modified by Ryan77, 1:02 PM 12/29/2002]
Corvette Clinic
Dept. CF
701-D Cornwall Rd.
Sanford, Fl
32773
Re: New differential drain plug kit for '63-'79 vettes....... (Ryan77)
Ryan
I saw that kit in the mag too. I would be concerned about getting chips inside the housing during drilling. I drilled and tapped the housing on my cars when I had them apart. The casting is thin so you have to be careful using a pipe tap because they're tapered so you don't get a lot of bite.
Gary
Gary
