LOWE'S CARPET GLUE AND SOUND DEADNER?????
Old 12-29-2002, 08:40 AM
frisk3
frisk3's Avatar
Default LOWE'S CARPET GLUE AND SOUND DEADNER?????
I read a post from someone on the glue from Lowes that was used to fasten down the carpet. I unfortunately did not make note of the brand etc. Does anyone know what it was? I've used 3M and was not impressed with the results on another of my cars and am looking for an alternative. Also does the foil like insulation sold at building supply companies really work in stopping heat from entering the cabin? What thickness & type should be used? Lastly is there a way to search the archives by subject (eg) carpet etc so I don't repeat topics already covered?
Thanking you all in advance and happy New Years.
GEORGE (frisk3)
Old 12-29-2002, 10:17 AM
Bobchad
Bobchad's Avatar
Default Re: LOWE'S CARPET GLUE AND SOUND DEADNER????? (frisk3)
I'm on my second can of the 3m stuff and have had no problems. The trick is to apply it to both sides and let it set for a couple of minutes until it gets tacky before trying to glue the two pieces together.
I got the thin Reflectix insulation from Lowes after reading several other posts. It is thin and supposedly does a good job. I won't have any personal experience until Springtime.
I've got a picture of it down, except for under the center console, at this link. http://home.attbi.com/~jchadwick/interior.htm
Bob
[Modified by Bobchad, 4:26 PM 12/29/2002]
Old 12-29-2002, 11:00 AM
Geoff1340
Geoff1340's Avatar
Did the interior on my 77 with Home Depot stuff & 3-M spray adhesive, made a very noticable difference in cabin comfort and noise reduction, of course chambered exhaust is still audible.... :yesnod:
Old 12-29-2002, 11:37 AM
Roadster71
Roadster71's Avatar
Default Re: LOWE'S CARPET GLUE AND SOUND DEADNER????? (Geoff1340)
I used Liquid Nails to do the roll insulation in my car. I got the insulation at a hotrod shop $18-20/roll
Old 12-29-2002, 11:45 AM
RMVette
RMVette's Avatar
I used the 3M also and had no problem. As stated previously apply it to both sides and let dry before laying the carpet down. Installing the heat shield helped in mine! :smash:
To LOWE'S CARPET GLUE AND SOUND DEADNER?????
Quick Reply: LOWE'S CARPET GLUE AND SOUND DEADNER?????
