Tire and Rim size for spare
Does anyone know what is a good size rim and tire that will fit in the spare tire carrier of a 69. I have a 15X8 ralley rim that I was going to use but was'nt sure what tire size to go with
Thanks :D
Thanks :D
Re: Tire and Rim size for spare (1969Diver)
I have gotten up to a 245/70 in a rear shark carrier. I had to let the two rear bolts that hold the bottom down a bit and put lock nuts on them to assure they wouldn't vibrate out. A 225/70 should fit fine without doing this. :cheers:
The original spare was a F70 15 on a 15 by 8 rim, which equates to about a 215 70 15. I would try to have a spare that is the same size as the tires you are running on the car. This would take into consideration a flat on one of your rear tires, where the same size tires would not put stress on your posi unit.
Ed
[Modified by ED DINAPOLI, 5:50 PM 12/28/2002]
Ed
