Let's play, name that part...
So what's the vacuum looking solenoid on the back side of the tach for? I noticed bubba has it blocked off.
Maybe be due to the HEI distrib in the car and the secondary tach he had installed in the cockpit?
[Modified by Monkeywrench, 3:33 PM 12/27/2002]
Re: Let's play, name that part... (Monkeywrench)
That is the windshield wiper door vacuum solenoid ports vacuum to the door when you turn the wipers on.
Re: Let's play, name that part... (silvervetteman)
Ditto. Must have had some wiper problems. Check out a vaccum diagram and you will see how the hoses connect to it.
Re: Let's play, name that part... (Eddie 96)
Yep, that's what it is. They're tough to find. I have a spare "just in case". There was a NOS one on EBAY a few weeks ago with a reserve of $125.00. Chuck
Thanks guys. Yeah the vaccum system on this car is a mess. One of these days I'm going to tackle it..
Thanks again!
[Modified by Monkeywrench, 6:41 PM 12/27/2002]
Thanks again!
I'll take it off your hands just to have a spare.:lol: :lol: :lol: If it dosen't work when you get your vacuum system done, it can be take apart and cleaned. See C3 tech tips, there is a procedure. There should also be an electrical connector plugged into it.
John
John
Re: Let's play, name that part... (theandies)
John
John
There are two vacuum hoses that connect to this thing and one "port" originally came with a small white foam filter on it. My filter port was capped also. This is a Bubba fix for inproperly working wiper door. After I cleaned it and removed this cap my door works perfectly. Look in the archives for posts relating to troubleshooting the door if yours dosen't work when you get it back together.......there is a bunch of info on this subject there.
John
[Modified by theandies, 6:49 AM 12/30/2002]
John
Long day in hell before I"d pay 100+ bux for one o those...even NCRS does not look up under dashes in local shows anyway.....
thing to do is go to junkyard look for mid 80's Dodge 3/4 ton van...up top in center of open hood is a vacuum solenoid....I have one on my van...I dunno what i'ts function is..as it's not troublesome....at any rate, I did prove it works the same action as the GM one on our vettes.....have at it...
GENE
GENE
And here is a link how to repair that thing:
http://www.71corvette.com/wiper.html
Can be found on http://www.corvettfaq.com
They also offer complete posts about the entire vacuum system.
