Which electric fan are you using?
Old 12-27-2002, 10:00 AM
Eddie 70
Support Corvetteforum!
Eddie 70's Avatar
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Which electric fan are you using?
Right now I am thinking I am gonna go the electric way. I have a vibration in my fan that comes in around 2000RPM. I know it is my fan because I removed the fan and ran the motor and the vibs are gone. Now I am thinking the electric fans are the way to go. Which fan are you guys using. I want something that is going to be reliable and keep me cool.
I have installed aluminum pulleys that take up most of the snout on my water pump so a new fan is out. There is only about 1/8 inch of the snout sticking out for the clutch to align on.
Any help is greatly appreciated.
Old 12-27-2002, 10:10 AM
Fevre
Fevre's Avatar
Default Re: Which electric fan are you using? (Eddie 96)
I went with these:
I lied, I actual have these:
http://store.summitracing.com/partde...57#largerimage
Only 2 1/4" thick.
SPALS is supposed to be the best but for about half the price these are working great even with about 400 hp.
I decided not to get the thermostat since it was the thermometer type and I had bad luck with them in the past. I have it hard wired to a switch for now but plan on wiring for automatic turn on when I switch to TPI.
[Modified by Fevre, 9:51 AM 12/27/2002]
[Modified by Fevre, 9:52 AM 12/27/2002]
Old 12-27-2002, 10:28 AM
terryrudy
terryrudy's Avatar
Default Re: Which electric fan are you using? (Fevre)
And for 1/2 that price again, you can go with Late model Camaro fans: http://www.corvettefaq.com/redir.asp?site=358
-terry
Old 12-27-2002, 10:34 AM
PROSOUTH
PROSOUTH's Avatar
Location: Manchester, Dead Center in the Middle of TN 25 miles to Jack Daniels,10 miles to Geo Dickle, and .8 mile from the Liquor Store at I-24 Exit 114
St. Jude Donor '05
Default Re: Which electric fan are you using? (terryrudy)
And for the same price you can get an Aluminum Radiator from Summitt and a set of late model Camaro/ Firebird fans! JIM
:iagree:
Old 12-27-2002, 10:36 AM
Fevre
Fevre's Avatar
WOW those things are thick!
Old 12-27-2002, 10:41 AM
GrandSportC3
GrandSportC3's Avatar
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I use dual Flex-a-Lite + single PermaCool 16" HP fan (2950 cfm)...
The PermaCool actually cools better than the Flex-a-Lite duals.. for half the price.. I'm actually thinking in removing my Flex-a-Lite duals and adding a second PermaCool fan...
:cheers:
Olivier
Old 12-27-2002, 10:47 AM
Fevre
Fevre's Avatar
Default Re: Which electric fan are you using? (GrandSportC3)
I bet the problem you are having is that you have the duals as pushers not pullers, that kills their efficiency. I had the same single fan as you as a puller and it did not work as well as the duals as pullers.
Old 12-27-2002, 10:52 AM
PatsLs1vette
PatsLs1vette's Avatar
i have the dual flexalites.like fevre pictured
Old 12-27-2002, 10:59 AM
GrandSportC3
You are right... The Duals won't fit as pullers on a 68... Damn - another 68 only feature is the smaller radiator...
:cheers:
Olivier
Old 12-27-2002, 01:50 PM
Cor6996vette
Cor6996vette's Avatar
Hi GrandSportC3,
Since you had experience with both Permacool and Flex-a-lite . What is your recommend for my 69 , Permacool one fan or two?, same with flex-a-lite one or dual , push or pull and what kind of wiring kit and bracket and fitting requirement? I am really appreciated. on the process of ordering :smash:
Old 12-27-2002, 02:05 PM
GrandSportC3
Default Re: Which electric fan are you using? (myisa69)
Hi GrandSportC3,
With a engine with more or less stock output (up 350 HP) a single Permacool 16" HP fan should be enough cooling... Another Forum member (I don't remember who) runs a single Permacool fan in Arizona and has no overheating problems.. I run 3 fans because my engine is pretty radical and needs much better cooling than a regular engine...
I usually only run with the permacool fan running and the Flex-a-Lites are switchable.. In Winter I never turn on the Flex-a-Lites.. I personally like to have more than one fan.. just in case if one breaks.. you still have another one... but for cooling alone - one should be enough
:cheers:
Olivier
Old 12-27-2002, 02:07 PM
The Money Pit
The Money Pit's Avatar
I run the Permacool 16". Originally had a flex fan on with the billet pulleys and after one 6000 rpm blast,the fan was wobbling.
Old 12-27-2002, 11:24 PM
72Shark
72Shark's Avatar
Question??? I see that the FLX 210 is the recommended dual fan setup for my '72 smallblock. Do I need anything else beyond what comes with the fans?? Ecklers sells a kit (overpriced of course), but also requires a "dual fan harness" = $50, and a cooling fan switch = $40. Are these additional parts needed??
Old 12-27-2002, 11:33 PM
Smokehouse69
Smokehouse69's Avatar
Cruise-In VI Veteran
Cruise-In VII Veteran
Dual Spals from DeWitts! So far one of the best improvements I've made on my car. It works great even with my old copper radiator, on at 195 off at 175.
Old 12-27-2002, 11:41 PM
OkeeGuy
OkeeGuy's Avatar
i went with this one with the Painless Wireing harness...
http://store.summitracing.com/partdetail.asp?part=10099
[Modified by SIGNGUY, 11:45 PM 12/27/2002]
Old 12-28-2002, 08:39 AM
Frankenvette
Frankenvette's Avatar
Default Re: Which electric fan are you using? (SIGNGUY)
I use a single 16" fan that I got used for $45.00 plus a painless wiring harness. Never crack 185 degrees on a mostly stock 350ci. The best thing about an electic fan is getting rid of the factory fan shroud. I actually have room to work in the engine bay and can pull the radiator in just a few minutes.
Jim
Old 12-28-2002, 11:43 AM
0Mike69@ECS
Former Vendor
Mike69@ECS's Avatar
Cruise-In III Veteran
Cruise-In V Veteran
Default Re: Which electric fan are you using? (Smokehouse69)
:iagree:
I went with the Spalls and a Griffen HP rad... even on the hottest days my car comes up to temp, and stays there. I can idle all day long in 100 + degrees without a worry. Definately a good decision in my book. Yeah it cost a little more, but I'll prob never worry about cooling again!! :cheers:
To Which electric fan are you using?
Old 12-28-2002, 03:19 PM
Fevre
Fevre's Avatar
Default Re: Which electric fan are you using? (Ed T)
Right now I am thinking I am gonna go the electric way. Which fan are you guys using. I want something that is going to be reliable and keep me cool.Any help is greatly appreciated.
bahahahaha :lol:
What's the cfm rating on that? :jester
Old 12-28-2002, 03:57 PM
spikezz4
spikezz4's Avatar
Dual 90-96 Corvette fans & shroud. Available at swap meets for $70-160. Replace both motors with new GM motors and off you go. It will cool well over 400 HP in sunny Florida when using an aluminum radiator.
Spike
Old 12-28-2002, 04:38 PM
vettedan
vettedan's Avatar
I using dual electric fans out of a '95 Z28 . I had to slightly modify the fan s to get them to fit. they push a lot of air and the engine never overheats. The best part about the fans is they were specifically designed for the LT1 engine.
Dan
Quick Reply: Which electric fan are you using?
