HELP---removing dash for new speakers
Need help, I am having problems removing my instrument panel above the steering column so i can replace my factory speakers. I had no problems getting to the passenger side. I have removed every screw that I can see, but still no luck. Surely i don't have to take apart the sterring column. Any ideas? help would be appreciated
Thanx
Thanx
St. Jude Donor '06-'07
Re: HELP---removing dash for new speakers (VetteRN)
You have to drop the column several inches to get out the driver's side. I'm sure there are a few posts in the archives that can help you with this. It isn't too involved, and it will help if you take a few minutes to pop off the steering wheel. Sorry I can't give you detailed instructions, but I've done it myself, and if I can do it... :cheers:
If you take the drivers pillar post off, you should have enough room to lift the top pad up and get the speaker from there. Remember there is a securing screw for the top pad in the middle of the dash.
Anyway, that is what I did. Lifting the pad gives you about 4" to work with. If I remember right the speakers are held on with nuts. I used a 1/4" rachet to get them off and on.
Hope this helps.
Terry
Hope this helps.
Terry
Re: HELP---removing dash for new speakers (trw)
You don't have to remove the driver's side dash to replace the speakers. Don't ask how I know. Remove the inside lower trim on the windshield frame and then there is one screw holding it in the center of the dash and clips that hold it to the front of the car. Pulls right out with some twisting.
Re: HELP---removing dash for new speakers (Bobchad)
Bobchad, Nice web site. I have a 77 and am doing a lot of the things you have done already. The pictures sure help.
Re: HELP---removing dash for new speakers (gmcclurg)
Glad you like it. I am trying to post what I have done with pictures and post what I want to do as I find the links. That way I'll have it when I need it.
You come up with any good how to links, let me know and I'll add them.
Bob
Bob
Hope this helps.
Terry
Hope this helps.
Terry
Re: HELP---removing dash for new speakers (SharkAttack)
Thanks for the input, I removed bothe pillar posts and also dropped the sterring wheel a bit, was able to replace the speaker without a prob. Am loving my new stereo!
Go to my website at the following link and you may find some ideas that will help; http://mywebpages.comcast.net/vettfixr/page19.htm
