2 birds with one stone - tpi and 5 speed help needed.
Got an idea of buying a donor camaro with tpi and 5 speed to get the 2 things I want. Now I need info or websites to identify the best year to look. Guessing I want a tpi with MAP and a world class t-5, both which I believe where available on the IROC at the same time but unsure of what year/years.
Thanks in advance
Chris
BTW Belated merry x-mas!
Thanks in advance
Chris
Re: 2 birds with one stone - tpi and 5 speed help needed. (Fevre)
well 89 still had maf so i would say 90 and up would work for you
http://www.chevythunder.com/index.htm
[Modified by patsnitrovette, 11:02 AM 12/26/2002]
Re: 2 birds with one stone - tpi and 5 speed help needed. (patsnitrovette)
Thanks Pat
Do you have MAP or MAS, looks like MAP. After doing to some reading on that website looks like the MAS might not be a bad idea, all though the MAS looks a little simplier. I am planning on getting a holley commander 950 to control it since I do not want to get a new chip everytime I want to play with new parts.
im running a mass air flow system heres how i did my air intake so i get cold air from out front into a vortex air filter(idea from 70 ls-1) http://forums.corvetteforum.com/zerothread?id=455736
Cruise-In VII Veteran
St. Jude Donor '07
I run a MAP system with no problems. Still working on cold air intake idea, but my current system does not lose to much hp to heat. I do feel that a MAF system is more responsive to cam duration, ie does not die at idle with a 5 speed. I run a VSS sensor that sends a signal to the ECM that tells the ECM the car is stopped and not rolling. Just an extra sensor to help the ECM know how to feed fuel.
Re: 2 birds with one stone - tpi and 5 speed help needed. (Budman78)
Thanks for the input guys. If I can find a decent IROC I'll take get the TPI and 5 speed then I can use it for a 1/4 mile beater. :)
