Any other suggestions on a Headlight switch...
So I am switching my lower dash pad out, but I'm finding that the Light switch is damaged...so My questions is...does anyone see any problems with fabricating my own light switch including dimmer instead of the stock light switch??? Any thoughts...
I was going to separate the dimmer and put the lights on a seperate toggle switch and then put the dimmer on a rolling switch that can adjust the inside lights as well...along side anoher dimmer switch that will control interior lights...
So does anyone see or no of a problem with doing this???
Thanks
Well, we had rain today, but it looks like everyone else had snow...Brrr.. :yesnod:
Thanks
Re: Any other suggestions on a Headlight switch... (Gotta Fix my '76)
It would be cheaper, and easier to simply buy a new correct headlight switch. How are you going to hook the vacuum lines up to operate the headlight doors?
George
George
Re: Any other suggestions on a Headlight switch... (stingray72)
Someone before me has already done the cross over process and I have fixed headlights inlayed into the front end....Maybe it will be cheaper to buy the same switch... :thumbs:
