Install of edelbrock fuel pump on 350ci ?
Hello everyone,I just read somebody asking about upgrading there fuel pump.I have a new edelbrock fuel pump I tried to install last year It mounted up fine but the fuel lines were the problem.On the brock pump the the out lets were to close to the car frame and I coulnd'nt fine the right adapters around here.I see they sell what I am looking for in summit.Has anybody else done this install before ? Would you describe the parts or a part# for what I need Theres no room for any adapter or anything else.I think Iam looking for a pipe thread that threads into the fuel pump and turns to a 90 degree turn any help would be great Thanks everbody.Dale (Merry X-mas & Happy new year) :thumbs:
Re: Install of edelbrock fuel pump on 350ci ? (SLO RDE)
do you have the style that you can remove the base and swivel it?if so remove the screws from the bottom and swivel the base till you have room for fittings.
Re: Install of edelbrock fuel pump on 350ci ? (patsnitrovette)
Same problem here. I had to order the bottom feed plate,and bring the inlet line in from the bottom.
Cruise-In III Veteran
Re: Install of edelbrock fuel pump on 350ci ? (The Money Pit)
