Exhaust shop in south Jersey needed.
I need to get full exhaust system done, including putting headers on. Can anyone recommend a good shop ??
Re: Exhaust shop in south Jersey needed. (Metal_Wulf)
I went to Mufflex in Trenton. They did an excellent job. He specializes in custom high performance exhaust. Talk to Denny, he is the owner. Not a real pretty shop but he does very good work. He will install headers also. Not the cheapest guy around but good work is not cheap.
You might want to try MIKE69 here on the forum. He's working with EastCoast Supercharging now and would be close to where your looking. These guys do it ALL................ JCL :yesnod: :yesnod:
Re: Exhaust shop in south Jersey needed. (patsnitrovette)
I was going to go with
I was going to go with Petersons originally, but they won't touch the manifolds, all they'll do is run the pipe. And I really can't drive an hour+ with open headers...
[Modified by Metal_Wulf, 11:24 AM 12/24/2002]
Petersons exuast on rt.30 in egg harbor city,but there not cheap either.
What you can do is install the headers and get some cheap flexible tubing from Pep Boys and connect teh header collectors to the original exhaust. This will get you to the shop and then have then take or cut the rest of the system off. The flexible tubing is only a couple of bucks and can be bent in any direction. It's Bubba at work but it gets the job done.
Re: Exhaust shop in south Jersey needed. (Gordonm)
:cheers:
I used the flexible tubing to get my car to the exhaust shop after installing the headers myself. Works great!
What kind price did they tell you?
