Muncie help!!
Muncie help!!
So I'm installing the new Hurst, and I think a bolt breaks off when tightening up the bolts that feed into the bottom of the transmission mount. But then the bolt falls out, and I realize that the aluminum threads in the Muncie just "broke" and stayed on the bolt! WHAT DO I DO NOW besides cry?? How can this be fixed?? Helicore???
Re: Muncie help!! (72Shark)
helicoil best way, but you might try some thread restorer I think pep boys or autozone sells it. It is a little tube of blue stuff that makes new threads. :chevy
Re: Muncie help!! (LT1driver)
The heli coil works great. If done right the threads are stronger than the original. You now have steel threads instead of aluminum. You can try thread restore I have not had much luck. It depends on how much (if any) thread is left.
