Delco ignition parts online?
Wheres the best sites to research and pruchase Delco ignition control modules online? Once i get it apart im gonna attempt to match it up by using the # on the module. Its on another vehicle, not the vette. I have no idea what year the dist is. Its a 5 pin module. 3 on one side and 2 on the other. So far, ive only been able to find the 4 pin and 7 pin HEI modules, but havnt seen a 5 pin. Thanks for the help and sugestions.
[Modified by Jvette73, 11:41 AM 12/22/2002]
Re: Delco ignition parts online? (Jvette73)
If I remember from you original post it was in a 84 Blazer? Then the Blazer would have been a 305 "H" code engine to use the 5 pin module. If that is correct then the module number you will need is Delco # D1918 and the GM is #10482821. Not a cheap module. You amy be better to find a non-computer controled distributor instead.
One of the places I have had good luck with for Delco parts is rockauto.com
Re: Delco ignition parts online? (Big Fish)
Excellent help guys and thanks for the part # Pete. Armed with the info I need, I just need to get off my rear and do it. Happy Holidays to you all.
