rear main seal leak?
If you have a leaking rear main seal should it leak while the car
idles in the driveway or only under load on the highway? I thought
i had a bad seal but i don't get any oil while the car idles.
thanx wade
thanx wade
Cruise-In VI Veteran
Cruise-In VII Veteran
Re: rear main seal leak? (wadey)
I've noticed the same thing with rear main seal leaks (and other leaks) in the past. My leaks have always seemed to occur when the car was parked and allowed to cool for several hours. So I assume that the heat produced by the engine cause enough expansion that the seals stop leaking.
As far as your under load observation I guess that oil pressure might have soemthing to do with it. At idle my car is running about 30lbs of pressure, while cruising at 2500-2700 rpms I am running 55 psig of pressure.
A bad PCV valve or a plugged breather can also promote oil leaks on a running car, vapor pressure inside the engine can build up and cause things to leak.
It might leak more when the oil is sloshing around in the pan. Either way it's not too hard to fix in a vette. Messy, but not hard. I just changed one in my 1954 International R100. It had the rope type seal. No way I was going to be able to get a new top half in there, so replaced the bottom half and called it good enough. This truck would leave a spot overnight the size of a mouse pad (bad leak). Now I rarely see anything at all, and even then it's like pencil eraser size. On a truck this old that is pretty good.
Re: rear main seal leak? (Racer16k)
I have a leak at the rear of my intake manifold. The oil drips all the way down to the backside of the oilpan making it look like a rear main seal leak. I have already changed my rear main seal and thought it was still leaking when I discovered the oil leak at the intake.
Re: rear main seal leak? (Frankenvette)
