torque setting manifold
Cruise-In VI Veteran
Cruise-In VII Veteran
Re: torque setting manifold (yogi78)
I'd guess that the torque settings would be the same for any aluminum manifold unless there were specific instructions otherwise from the manufacturer.
Re: torque setting manifold (Smokehouse69)
25 ft/lbs. Use thread sealent on the bolts and retorque them after you run it for a while. I checked mine for the first couple of days until I found them to stay tight.
