Q-jet info
Re: Q-jet info (Burgandy 69)
Go to http://www.corvettefaq.com and find Lars Q-jet paper. More Q-jet stuff there. The real trick with Q-jets calibrating it for you specific set up. Rebuilding is fairly easy but it won't fix a carb that is set up for something else. Lars paper will tell you a lot.
Re: Q-jet info (Surfer69)
Surfer,
Make sure the kit you bought has a accel pump that is compatible with current fuels. The kit I had contained the wrong pump. The fuels now days contain alcohol which caused my pump to swell in the bore and not operate properly. It caused hard starts and a really bad bog when you hit the throttle, really dangerous when maneuvering in traffic.
Stew
Stew
Best book on Q-jets:
Rochester Carburetors by Doug Roe
I am sure of the name and 90% on the title. Good discussion on rebuilding Q-jets with diagrams and pictures of every step.
Between this book and the Lars' tech papers, the Q-jet becomes a lot easier to work on.
Re: Q-jet info (SteveG75)
