First attempt at cranking up new motor a no go--help.
Ok. Today I tried to crank up the new motor for the first time, finally. It turned over until gas got to the carb, and then just backfired gasoline out of the carb several times. I must have the distributor stabbed wrong. I stabbed it with the number one piston at TDC and the rotor pointing at number one spark plug wire. Did I miss something? Is this not the correct way? :cheers:
Re: First attempt at cranking up new motor a no go--help. (mp77)
Got briefed on timing alot recently. Did the same thing, stabbed the distributor wrong and had to find the right tooth. Maybe advance or retard the distributor in the tooth its in......
From what I learned, and I may have this wrong, back through the carb means retard. (No pun intended) :)
Fromwhat I recall, we had the rotor pointing at "just before" no. 1 plug wire at TDC.
[Modified by 71,454,4spd, 5:07 PM 12/18/2002]
Are you sure it was TDC on the compression stroke because it sounds like the timing is still off. The piston could have been on the exhaust stroke instead.
mp77,
Check out Lars paper on how to set your timing. You can find it at http://www.corvettefaq.com in the engine section.
I had the same problem when I went to start mine the first time. You are probably only a tooth off or 180 degrees off.
Good luck.
Good luck.
Re: First attempt at cranking up new motor a no go--help. (George Dickel)
It really doesn't matter where the rotor points, if you install the distributor just install #1 wire on the terminal where the rotor points at TDC #1. Just make sure you're not on TDC before intake stroke.
Marck
[Modified by Twin_Turbo, 5:33 PM 12/18/2002]
Marck
I held my finger on number one plug hole as I turned the crank and the compression pushed my finger away. :cheers:
Re: First attempt at cranking up new motor a no go--help. (Bob Blackmon)
And if that doesn't do it check your plug wires to make sure there not crossed. It's pretty easy to do if you still have all the covers on.
