Under carpet insulation at Peppy Boys
Old 12-16-2002, 11:14 PM
shoptek
shoptek's Avatar
Default Under carpet insulation at Peppy Boys
For what it's worth,
I picked up a roll of this stuff for $18.99 figuring it might be worth a try. It is padded on one side, and "foiled" on the other. It is 4' X 6', is less than a 1/4" thick on the roll.
I've seen insulation in the Vette parts catalogs that mention something to the effect of "using NASA technology" that costs a bundle. This stuff too mentions NASA technology.
It is made by Spectre, in Las Vegas if anyone is interested. I know a lot of you are using the Home Depot/Lowes bubble between foil stuff, and I'll probably use that in the rear area too since 1 roll wont do the whole car.
Old 12-16-2002, 11:19 PM
Stoge
Stoge's Avatar
Default Re: Under carpet insulation at Peppy Boys (shoptek)
Thanks for the heads-up!
Old 12-16-2002, 11:21 PM
77BlueL82
77BlueL82's Avatar
I used the same padding when I did my interior. So far so good. :yesnod:
To Under carpet insulation at Peppy Boys
Quick Reply: Under carpet insulation at Peppy Boys
