How do I choose a tire?
I have pretty much settled on 17'' TTII's. (I am guessing by everyones input 17X8 with 4'' backspace will bolt right on.) Size I am guessing will be aprox 255 50 17s. I will research what will give proper clearance and height in more detail. But with so many tire options(brand and model), how do I choose? Is there any way to compare tires apples for apples? My uses are an agressive street tire. I will probably never go over 100. (at least for more than a few seconds) I want good handling and ride. Wet traction is not a issue as I dont drive it in the rain. I dont even know where to begin to determine what is good or not. Sounds silly but the look of the tread pattern is about all that I am guessing on right now. Suggestions?
www.tirerack.com
they have reviews for most of their tires, sell every tire, and their tires are dirt cheap. i dont know what to suggest, i am just here collecting info on a corvette i have to do some work on - i like my old bmw's better. i dont know if falken azenis are made in a size that would fit your vette, but they have a pretty cool treat pattern, stick like glue, are cheap, and suck azz in the rain ;)
Cruise-In IX Veteran
Re: How do I choose a tire? (DollaGreen)
If you want to keep close to a stock tire diamter of 27 inches you will need to get 255/50/17. There are only two companies that make tires in that size. One is Nitto the other is Bridgestone. I am getting the Bridgstones for my car they are the RE 730s. I think some others on the forum have the nittos.
Mark B.
Mark B.
The bridgestones have a very good reputation. I've been seeing quite a few Kuhmo Ecsta tires on performance cars. I have BFG KDSWs on my wife's Mustang and they are excellent.
255/50/17 is the only size I've found that matches 27" OE diameter.
