Expansion tank blues - advice needed....
Yikes - my tank is 'defective'..... I tried sealing the heater hose outlet -but now it's dripping. :cuss :mad
It's off a mid-year vette and has only 1 outlet.
Since my heater doesn't work - I'm thinking of connecting the outlet to my water pump. Then plug my intake inlet for the heater hose.
In the meantime - I'm searching for a new expansion tank - the long, brass type - so it'll be correctly installed on the fender well as the factory did on A/C cars. :cool: Any tips or recommendations would be helpful. :confused:
Re: Expansion tank blues - advice needed.... (verskel)
I'm using custom made tank out of aluminum, works for me...
[Modified by groovyjay, 4:18 PM 12/16/2002]
Thanks, maybe later when/if I start my new project, I can make two, one for me, one for u! :cheers:
Cruise-In III Veteran
Can't weld it? :confused: Or take the broken fitting off and sink a threaded fitting in with an o-ring?
Verskel,
I have a long Brass exp tank that I will soon be replacing with an Alum tank. Make me a reasonable offer and its yours.
will_shepherd@hotmail.com
St. Jude Contributor
Re: Expansion tank blues - advice needed.... (flynhi)
Will, if he don't want, I sure do! Mine's got a nasty looking weld job & I've been wanting to replace it.
JB
[Modified by JB, 5:44 PM 12/16/2002]
JB
