Evaporator Canister Removal
What is the best way to eliminate the fuel evaporator canister and route the two vapor lines that feed it?? Just plug them??
:cheers:
:cheers:
Re: Evaporator Canister Removal (l2vette)
Anyone! ttt
Why remove it? It costs ZERO horsepower to operate the system and weighs almost nothing.
If your concerned about weight, put half a gallon less fuel in the tank when you fill up.
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
I don't think that you can just plug them as they are a vent.
One thing that I did notice when I disconnected the one on my project truck. Any time I parked it in the garage, the next day the garage smelled worribly of gasoline fumes -- :U
I connected it all back up right after that.
Re: Evaporator Canister Removal (BSeery)
The evap system is designed to be used in conjection with the fuel tank and the pvc- carb set up. There must be a better way!!
