Interested In Comp Cams XE
Here is a link to the page with all the graphs so you can compare all of the XE and HR cams. http://www.compcams.com/information/...ts/DynoSheets/
All of the test engines are the same just a difference in cams. Until you get up the the biggest cams and the heads change.
[Modified by Eddie 96, 3:08 PM 12/16/2002]
Re: Interested In Comp Cams XE (Metal_Wulf)
sweet! I could use this to go along with my post...
:cheers:
:cheers:
Re: Interested In Comp Cams XE (Eddie 96)
You are the reason I looked up the website for more details. I listed you in my other post about Compression Ratios.
I'm going with the XE262 when I do my build up this Jan-Feb. the roller is just too expensive...
The XE has all the torque. But the others have the HP. I am gonna be using torque alot more often. This is just a cruiser I have.
