Carburetor adjustments- Help!!!
I am running a Demon 850 with Vac secondaries and an electric choke....
I am in the process of figuring out how to adjust the carb. I have limited experience in this area. The car is running rich right now, so I want to lean it out. How should I go about adjusting it? Should I turn the mixture screws IN one full turn?
How can I tell if it is set correctly without an analyzer? Any ideas will help.
I also need some guidance on adjusting the electric choke. Where do I start??
Please help!!!
Thanks,
Bob
Please help!!!
Thanks,
Bob
Re: Carburetor adjustments- Help!!! (Bob Turner)
You need Lars. He is our 'Carb Guru' and can help!
Find a thread where he has responded and send him a detailed note describing your situation. He WILL help!
Lars posted to this thread with some good carb advice. You can contact him (just left-click on his name:
http://forums.corvetteforum.com/zerothread?id=449626
:seeya
[Modified by TedH, 2:40 PM 12/16/2002]
[Modified by TedH, 2:46 PM 12/16/2002]
:seeya
Bob pretty sure Demons are very similar to Holleys so this should help:
https://www.corvetteforum.com/techti...=108&TopicID=3
Worked great for me. :yesnod: Make sure you follow the steps in order.
