Short in horn
Short in horn
I've got a short somewhere in my horn. If I turn my steering wheel a little bit to the right of dead center my horn blows. Have any of you had a situation like this before and if so where might be the best place to start looking?
Thanks for your help.
Chuck W.
Chuck W.
Re: Short in horn (Red69L68)
I had a similar problem and I'm not sure if Bubba was in my steering column. If you take off the horn cap and the 3 screws which hold the metal ring to the column, you should have some sort of spring (mine looked like a Q-Jet power piston spring) and some type of metal (on mine, it was a srcrew) which makes contact with the metal ring. On mine, the screw was also coming into contact with the metal on the steering column.
Looong time ago mine did the same thing and I replaced this http://www.ecklers.com/product.asp?p...N0SM2EPT2U80E0. NOt sure if your is tele or not. This fixed mine.
Re: Short in horn (Robd)
In case you didn`t already know this, the horn button just pulls straight off. :cheers:
