Aft Seat Mounts on 73 Body
Old 12-15-2002, 01:07 PM
Silver73LS4
Silver73LS4's Avatar
Default Aft Seat Mounts on 73 Body
Here's one that I am hoping someone out there can help me with. I am in the process of installing seats in my 73. The 2 inboard aft bolts were broken off in the steel plate that is riveted to the underside of the floor so I removed the plates and drilled out the broken bolts. While I was there I noticed that there was nothing to bolt the outboard aft seat bolts in to??? It does not appear to have rivet holes where a plate once was so what is supposed to be there? I will likely drill and tap a plate similar to the inboard mount but I was curious what is supposed to be there. I can't seem to find a picture in the AIM but maybe I am missing it. Anybody out there run in to this before?
Thanks
:cheers:
Old 12-15-2002, 02:21 PM
trw
trw's Avatar
Default Re: Aft Seat Mounts on 73 Body (Silver73LS4)
Silver
The seats (for whatever reason) have three nuts attached to the body and the forth is just a nut and washer under the body.
If I remember right, I think the bolt goes through the frame or at least supporting material.
Hope this helps.
Terry
Old 12-15-2002, 05:48 PM
Racer16k
Racer16k's Avatar
The rear outer bolt attaches to the same part of the bird cage that the seat belt guides bolt to. Is yours rusted away? I had to make new ones when I made new sills for the bird cage.
Old 12-15-2002, 10:25 PM
NHvette
NHvette's Avatar
Default Re: Aft Seat Mounts on 73 Body (Racer16k)
I'm with Racer - should be a nut in the seatbelt reinforcement plate.
I think repairing it with a small plate (like the inside one) would be OK.
:iagree: :seeya
To Aft Seat Mounts on 73 Body
Quick Reply: Aft Seat Mounts on 73 Body
