70 350-300 HP Water Pump
Re: 70 350-300 HP Water Pump (Magic Fingers)
What in particular are you looking for. I can run out and take a picture of mine(setting on the shelf). It is a short water pump.
If this isn`t what you are looking for let me know and I will shoot some more.
Re: 70 350-300 HP Water Pump (Eddie 96)
Great pics! And the reinforcing ribs appeared in 1971, albeit in a different colour.
[Modified by paul79, 1:20 PM 12/15/2002]
The reason for the casting changes in 71 was due to a larger bearing then supplied in 70. The reinforceing ribs were necessary for extra shaft support.
Ed
Ed
Eddie, Thanks for the pictures.
Any chance you may be able to post the date on th casting. I can almost, but not quite make it out .
Thank You Again
Thank You Again
Sure here are the numbers for you.
Cast numbers GM 23 3782608
Date code A 18 9
The 8 could be a B or a 6.
Date code A 18 9
