'76 350 TRANY LEAK
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
'76 350 TRANY LEAK
I have a leak coming through the inspection plate on my 350 automatic. I assume it to be the front seal. What else would cause a leak in this area? Is the pump seal and the front seal one in the same on these trannys? :seeya
Re: '76 350 TRANY LEAK (Jud Chapin)
One and the same.Pump bolts have sealing washers,pump housing has a large o ring,and pump to case has a gasket.Most common problem is the front seal.
Re: '76 350 TRANY LEAK (kenincanada)
I assume the front seal cannot be fixed without pulling the tranny. I chased down all my tranny leaks, replacing almost all seals without pulling it. I am now down to losing about 1/2 ounce of fluid every week. Not bad, but you know how that must bother me; however, it doesn't justify pulling the tranny when it is working fine.
