What is the widest tire I can put on my Stock 74 Rally Wheels
Old 12-13-2002, 10:31 AM
Alwyn678
Alwyn678's Avatar
Default What is the widest tire I can put on my Stock 74 Rally Wheels
Is it 275/60/15....I do not want to change to offset Trailing arms
Old 12-13-2002, 10:45 AM
GDaina
Support Corvetteforum!
GDaina's Avatar
Default Re: What is the widest tire I can put on my Stock 74 Rally Wheels (Alwyn678)
just move the emergency brake cable so it sits on top of the trailing arm, then you can do it, else 255-60's will clear the bracket....larger size will run too close to the bracket and....well...u know what will happen when the tire meets the bracket....
Old 12-13-2002, 10:48 AM
Alwyn678
Alwyn678's Avatar
Default Re: What is the widest tire I can put on my Stock 74 Rally Wheels (GDaina)
Thanks for the Info :cheers: Now I have to find a Deal on some BFG's :cheers:
[Modified by Alwyn678, 10:50 AM 12/13/2002]
Old 12-13-2002, 11:11 AM
PatsLs1vette
PatsLs1vette's Avatar
i ran 275/60/15 without removing emergency brake cable,but other cars are different
Old 12-13-2002, 11:53 AM
Alwyn678
Alwyn678's Avatar
Default Re: What is the widest tire I can put on my Stock 74 Rally Wheels (patsnitrovette)
329.54 Delivered is not too bad a price from tire rack on the 255/60/15's for 4 :cheers:
Old 12-13-2002, 12:13 PM
corvettemack
corvettemack's Avatar
I have put a 295/50/15 on them before. However, I did have to cut the bkt
off that holds the e-brake cable. Those e-brakes are usally not worth having on an automatic car. The tire did stick out the lip of the fender about a 1/4".
however it fell in with the lines of the car. I'll show you a picture if you are interested. I ran the 255/60/15 on the front which is standard for the 78 up vettes. The front tire was 3/8" shorter than the rear but you could not tell the difference looking at it. One thing to think about that would be different on your 74 is the lip inside the fender is a little larger than the lip on my 80.
Old 12-13-2002, 01:59 PM
Alwyn678
Alwyn678's Avatar
Default Re: What is the widest tire I can put on my Stock 74 Rally Wheels (corvettemack)
Cool thanks for the tip Mack.I will probably stop by this weekend to get that horseshoe clip and the hardware :cheers:
Old 07-11-2013, 02:30 PM
54inches
6th Gear
54inches's Avatar
TTT for searching.
I think I am going to do 255s and 295s(unless I can find some 2015s).
Thanks guys!
To What is the widest tire I can put on my Stock 74 Rally Wheels
Quick Reply: What is the widest tire I can put on my Stock 74 Rally Wheels
