Is there an official Tech Bulletin for the lazy clutch pedal?
Enough people have had this issue now for Chevey to address it.. Have they?
If so can I see the bulletin and what their fix is?
Re: Is there an official Tech Bulletin for the lazy clutch pedal? (chuckster)
does not seem to be, acording to kewlbrz
http://forums.corvetteforum.com/zerothread?id=327507
:( :cuss :(
:( :cuss :(
Re: Is there an official Tech Bulletin for the lazy clutch pedal? (MySea5)
I can't believe that more people complained about a smelly A/C unit than their damn clutch pedal not returning... :confused:
Chuckster, C4C5spec. addressed this matter on the other forum. He claims there is such a fix and that it has come out the GM tech center. He didn't call it a TSB as I recall but it did involve changing the master cylinder and some other unidentified things. I have become interested in this topic as I am now experiencing this condition. Perhaps he'll read this and respond tonight.
Joe
Joe
Re: Is there an official Tech Bulletin for the lazy clutch pedal? (C54FUN)
Joe
Joe
It might just be a PI right now...
Cruise-In IV Veteran
Cruise-In V Veteran
I had mine fixed for the 2nd time under warranty last month. The first time they replaced the entire clutch assembly and it fixed the problem. But again after about 12K miles the problem returned. Took it to the dealer and this time they replaced only the master and slave cylinders. This alone did NOT fix the problem. I can still get the pedal to act lazy under heavy acceration and fast shifts. Kinda frustrated but so far it hasn't cost me a dime for the fixes, only time in the shop. I figure within a few more months I'll need a new clutch again and hope to go with the 2003 Z06 clutch (or the 2002 if the part #s match). I doubt I'll get another warranty fix though, but I'll try for it. Car has 34,450 miles on it right now.
...C4C5spec. addressed this matter on the other forum. He claims there is such a fix and that it has come out the GM tech center. He didn't call it a TSB as I recall but it did involve changing the master cylinder and some other unidentified things. I have become interested in this topic as I am now experiencing this condition. Perhaps he'll read this and respond tonight.
Joe
Joe
But the question is why all the secrecy. Clearly there is a design problem. The failure rate is high among cars that are run hard. But among affected cars, the flywheels, pressure plates, and clutch rotating discs all appear to be fully functional. That points to hydraulics....
So why the secrecy??? :confused:
Ranger
Cruise-In II Veteran
Cruise-In III Veteran
Re: Is there an official Tech Bulletin for the lazy clutch pedal? (Tormania)
Re: Is there an official Tech Bulletin for the lazy clutch pedal? (kewlbrz)
....Did they replace yours originally with a 01 clutch assembly?
After a lot of hassles with my dealer relating to botched installations, my situation was resolved this way. Two Chevy field engineers replaced my clutch with an 02 Z06 clutch and slave. Master cylinder was NOT replaced and it contained DOT-4 fluid. There were no indications of failure or abuse in any of the parts that were changed.
By 20K miles, the clutch pedal was acting up again on hard acceleration involving multiple shifts.
My 02's clutch pedal is acting normal so far at 1200 miles. Doubt it will last, however.
But the fact that GM is doing so many of these under warranty indicates that they understand that there is a design/QC issue. So why the secrecy on the particulars??
Ranger
[Modified by Ranger, 5:55 PM 6/24/2002]
Hi there,
First, the facts. GM and Corvette engineering have been working tirelessly on this issue.
Make NO MISTAKE here, this is fact. IF YOUR DEALERSHIP CONTACTS TECHNICAL ASSISTANCE, with the symptoms that are given. The repair will be given to them along with a technical assistance case number.
As I have stated numerous times, duplication of the problem must be seen, before the fix can be implimented. Some clutch issues, can be traced to other things, NOT JUST THIS FIX.
The supposed theory on the restrictor plate causing the issue, IS FALSE.
The theory on just a hydraulics causing the issue, IS FALSE.
Interrelation between components is what is causing this issue, only when driven hard.
I am NOT at liberty to disclose further information at this time, as there is NOT a TSB, only a preliminary document within the technical assistance network, that is available to all GM dealers whom need it.
This is fact, and should be taken as such, before the flames begin.
After 17 fixed at my dealership, NOT ONE reoccurance of the condition, even by drag strip usage.
Only half of these were warranty, the others were paid, and satisfied with the repair.
Besttoyouall, c4c5 :chevy
Re: Is there an official Tech Bulletin for the lazy clutch pedal? (c4c5specialist)
...This is fact, and should be taken as such, before the flames begin....
We appreciate that you have an obligation to protect the proprietary information of your employer. I certainly take NO issue with YOUR position. It's GM that I'm disappointed with.
The persistent fact is that clutch pedals of MANY members keep sticking and NONE of the parts that are being replaced are reportedly showing ANY APPARENT sign of failure. And once "fixed," the problem has a high incidence of recurrence (except the fixes performed by you. :) ). That fact would seem to merit an explanation from GM. I suppose at some point it will. Either officially or through the usual informal channels.
Ranger
[Modified by Ranger, 8:37 PM 6/24/2002]
Hi there,
First, the facts. . . . .
Re: Is there an official Tech Bulletin for the lazy clutch pedal? (Ranger)
Hey Ranger,
You know how the net can be when people hear things that they dont want to.
Just a forebear, thats all.
I know your intentions are good, asalways.
Besttoall, c4c5 :chevy
Thanks for your replies C4C5...I was starting to have this problem w/ my 01 before I traded it. I hope it doesn't happen to my Z. Maybe a tsb will come out before then.
Dealer replaced my 01 Z clutch using a new master,slave,flyweel,disc and pressure plate.Thanks to C4C5 for is assistence.
c4c5, if I was a paying customer, how much is involved? Cost?
Do I have to open the bellhousing?? (Long tube hassles)..
Re: Is there an official Tech Bulletin for the lazy clutch pedal? (MelloYellow)
How could I tell if my dad's is doing it? Will it just not come back up or something?
