Vacuum Diagram
Old 04-15-2002, 05:19 PM
MRZ28HO
MRZ28HO's Avatar
Default Vacuum Diagram
Does anyone know where I can get a 1978 L48 (auto, Low alt.) specific vacuum diagram for the emissions hoses? We have a 1978 GM Service Manual, but the vacuum ports shown on the carb diagram do not match our Quadrajet. :confused: I ordered an emission hose kit from Eckler's (specific to our car) and it came with alot of useless hose. Some not long enough (for the charcoal canister) some not the correct diameter, and only ONE Tee fitting. And worse of all, no diagram to show how it show all be routed. I did a search on the 'net, but no one has pictures of (their 1978 or similar) engine bays. :( Can anyone of you guys that has a federal L48 auto, low alt. post a close up picture of your vacuum diagram or a shot of your engine bay with the air cleaner removed. Only requirement is that the vehicle must be as close as possible to stock (are there any left? :) ). Thanks! :cool:
MRZ28HO is offline
Old 04-15-2002, 06:08 PM
MRZ28HO
MRZ28HO's Avatar
Default Re: Vacuum Diagram (lbell101)
You are the man!
MRZ28HO is offline
Old 06-22-2011, 05:28 PM
Will94ZR1
6th Gear
Will94ZR1's Avatar
what about a 94 lt1 vacuum diagram
Will94ZR1 is offline
Old 06-22-2011, 05:39 PM
pewter99
Support Corvetteforum!
pewter99's Avatar
Received 1,194 Likes on 704 Posts
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
closed ancient thread
pewter99 is offline
To Vacuum Diagram
Quick Reply: Vacuum Diagram
