Weight Reduction.....
Old 04-08-2002, 11:00 PM
OrangeC4
OrangeC4's Avatar
Default Weight Reduction.....
Has anybody done any weight reduction on there vette? If so, where did you start?
Old 04-08-2002, 11:32 PM
ASRoff
ASRoff's Avatar
Default Re: Weight Reduction..... (OrangeC4)
Emissions equipment :D
Old 04-08-2002, 11:45 PM
Mr Mojo
Elite Torch Red Member
Support Corvetteforum!
Mr Mojo's Avatar
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I started with removing the spare and carrier, front sway bar, all the junk I carried in the hatch area. Next is the skinny wheels up front.
Old 04-09-2002, 12:05 AM
Drewdog
Drewdog's Avatar
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Weight Reduction..... (Mr Mojo)
check out this thread:
http://forums.corvetteforum.com/zerothread?id=272385
so far I've removed the front sway bar and taken the mufflers off
Old 04-09-2002, 05:24 AM
VetteRacer282
VetteRacer282's Avatar
A/C and smog equipment.
Havent weighed it all yet, but guessing close to 100# total. I'll try to weigh the smog stuff, and what A/C stuff I have left.
Spare tire setup should save a bit too. Might try to weigh that also :)
There is also the CF hood, Lexan windows, all those non-street suggested items. Race seats can save a bit as well.
Goodluck
Matt
Old 04-09-2002, 06:27 AM
GlockLT4
GlockLT4's Avatar
Default Re: Weight Reduction..... (VetteRacer282)
Mufflers! :yesnod: :yesnod: :yesnod: :jester
Old 04-09-2002, 06:54 AM
NoWorries
NoWorries's Avatar
I just added 30+ lbs in my trailer hitch!
Totally defeats the mufflers, antenna, wheels, and other stuff I've done.
Old 04-09-2002, 05:49 PM
VetteRacer282
Default Re: Weight Reduction..... (NoWorries)
You may have added that weight, but it serves a good purpose atleast.
I am a gram counter on my bikes, but always put function first.
Matt
Old 04-10-2002, 02:53 AM
The Dingo
The Dingo's Avatar
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
Check this thread out...:
http://forums.corvetteforum.com/zerothread?id=252827
Old 04-10-2002, 12:54 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Default Re: Weight Reduction..... (Red 90 L98 Coupe)
I got this off the BSP mailing list
-----Original Message-----
To: bspvette@topica.com
Date: Tue Apr 09 15:28:04 PDT 2002
Subject: Re: [bspvette] How light can a C4 Go?
The last time I weighed my 86 at the Meridian Tour last year it weighed 3100 lbs with a full tank of gas, and the glass top in place. I've replaced most of my smog stuff, gutted the cat and have a full Borla muffler system. Since then, I've replaced the power seat rack (about 20 lbs.) with a manual seat rack on the drivers side (passenger side was already manual). I've put a mini starter on (6.5 lbs vs. 25 lbs for stock) and plan to go to a dry cell battery with will save another 25 lbs.
My goal is to get the car down to 2900 lbs. in BSP/EII trim. How? lighter wheels and tires (60-80 lbs. savings using Hoosier bias and Real Racing Wheels). 30 lbs. by removing the top. 45 lbs. by replacing Borla mufflers with single straight pipe out the center of the back. That would save me (20+19+25+70+30+45)=209 lbs and would place my car at 2891 lbs.
I still have the a/c and a nice stereo and speakers in my car and I drive it on the street. Taking out the A/C and stereo I could get it down to about 2820 lbs. Not bad for a big ol' heavy Corvette.
Now, think about SM2 trim. Replace the hood with lightweight fiberglass (85 lbs.) same for front and rear facia (20 lbs.) go for the super light seats (also legal in BSP would save maybe 20 lbs.) over base seats, a lot more for the sport seats. Then put in a LS1/6 motor which shaves another 100 lbs. Now where could we be? 85+20+20+100=225 so a full-on early C4 SM2 Vette could weigh 2595 lbs. Forget those blown Miatas!!
Old 04-10-2002, 01:21 PM
John Row
John Row's Avatar
Go on a diet. I'm trying to get rid of 50 extra pounds :mad .
Old 04-11-2002, 12:29 AM
Black 'n Blue
Black 'n Blue's Avatar
Default Re: Weight Reduction..... (BrianCunningham)
I've considered trying many of these same things, but I suspect that removing too much weight without altering the spring rates will make the car's ride pretty harsh. Also, getting pushed around by gusts of wind might be more dramatic, and hydroplaning on wet roads is likely to be more of a problem as well--especially for those of us who like to run the widest tires we can get our hands on.
Old 04-11-2002, 12:34 AM
OrangeC4
OrangeC4's Avatar
Thanks, this will come in handy. :cheers:
Old 04-11-2002, 04:02 AM
Drewdog
Drewdog's Avatar
:cool:
To Weight Reduction.....
Quick Reply: Weight Reduction.....
