Slow turn signal
Slow turn signal
My left turn signal flash is MUCH slower than the right. When the headlights are on, the left rear tail light is dim compared to the right. Additionally, when the headlights are on, I have no brakelight on the left. Rear tail light ground on the frame seems to check out okay and the bulb is new. Also, no connection problems with the steering wheel gang terminal. Any ideas?
Thanks in advance.
Thanks in advance.
Re: Slow turn signal (twotone82)
Try two new bulbs from the same manufacturer. My did the same thing and i finally ended up with two tail lamps with the same intensity. Make sure the cantact in the sockets are clean. also try manipulating the wire harness will someone is on the brakes and see if you can get it to come on. If it does, might have a broken wire.
