Worth of a set of Rally's
It was said that I might have better luck in the C3 forum so here I am. I have 2 15x7's and 215x8's on my car. I was wondering if there is a market for them? How much is a decent set like this worth? I have my eye on torque thrust II's. :cool: I think. Here is a picture of the car with the rally's from last spring.
Re: Worth of a set of Rally's (INMYBLOOD)
I just got a price on a complete set (4) of factory GM 15 x 8 Rally wheels with new trim rings and the correct factory GM center caps from a guy.
$600.00 for the complete set.
Still looking around to see what other prices I can find.
15 X 8's are fairly common and therefore arent quite as valuable as the 15 x 7 ( 68's use the 15 X 7 and if dated for a '68 may bring more to those who are trying to restore.)
If I am mistaken about the 15 X 7 someone please chime in.
Hey Gordon,
Check this:
:D
http://www.boydcoddingtonwheels.com
-Noel
[Modified by Noel Carboni, 9:31 PM 2/27/2002]
Check this:
:D
-Noel
Location: Your Fighting Tigers of LSU. 2003 National Champs
The 15x7's are only of value to a restorer if they are stamped for a '68 Vette. Otherwise, the 15x7 was produced for the Chevelle, Nova, Malibu, Camaro, Uncle Joe's tractor... catch the drift??
The 15x8's are of course Vette only, but again, only worth to a restorer if they match his date code requirement.
Hope this helps. :seeya
Re: Worth of a set of Rally's (flood)
Put em on ebay and im sure you will get way more than they are worth.
:cheers:
:cheers:
Where is the date code on a rally? I looked at them last night and the only place I saw a few letter was around the valve stem????????
Where can I look for the codes after I write them down???
Thanks.
