How do I Lube Rear Wheel Bearings?
I've had my survivor '71 for about six months now... I repacked the front wheel
bearings but I understand it's not so easy to lube the rears. I was skimming
through my Vette Brakes & Products catalog that arrived yesterday and noticed
that they have a "Rear Wheel Bearing Greaser" (pg 50, part #51607) for $19.95.
Anyone have experience with it? Is this a good way to lube my rears? Or should
I do something else, given that my rears have probably not been touched in
thirty years?
Thanks!
thirty years?
Thanks!
Re: How do I Lube Rear Wheel Bearings? (rollavette71)
rollavette71, just my .02 but i would not use them. I have read in the past where if you put too much grease in it the grease would push the seal out. I just got done rebuilding mine and would agree with this . also , once properly greased you won't need any more for a long long time :chevy :cheers: Rick
You could use the rear bearing lube tool, and give each bearing a few shots of grease, but I remember seeing/hearing that grease really won't get to the outter bearing doing it this way, plus you have to remove the spindle nut, and inner bearing, and then install a new nut (recommended) when doing this job iwith the lube tool.
Many forum members say the only way to do job right is to remove spindle / bearing assembly, and then you might as well install a new bearing once you're that far.
Me, I removed my left side three years ago, greased it and reinstalled, checking for proper clearance with my home made 'tool', and since it looked OK, I called it good, and like I said that was three years and 15,000 miles ago, and it's still OK, but maybe I'm just lucky.
