alright, to you stall speed experts which speed with this cam and gears....
Should I lean more toward 2700-3000 stall or 3500-3800 stall for the engine in my signature? Thanks to BAD-L88, I have 3.70's that are going in. So will I have problems with the converter still slipping at highway speeds with a 3500-3800 stall and 3.70's or will it be locked up? Should I go for the 2700-3000 stall or 3500-3800 stall? Like I said I'll be running 3.70's and heres the cam specs
Duration at .006 Lift: Intake 308° Exhaust 318° Centerlines
Duration at .050 Lift: Intake 234° Exhaust 244° Lobe Separation: 112°
Lift at cam: Intake .325 Exhaust .340 Intake Centerline: 107°
Lift at valve: Intake .488 Exhaust .510
Timing at .050 lift: Open Close
Intake 10° BTDC 44° ABDC
Exhaust 59° BBDC 5° ATDC
Oh yeah, this is a TH350 tranny
[Modified by TravMsns, 5:54 PM 2/26/2002]
Re: alright, to you stall speed experts which speed with this cam and gears.... (TravMsns)
I wish I had those Gears...(3.73's).....I am not sure about the stall however..I only am running a 2400
Of the two I'd go w/ the 2700-3000 stall- the other would be too loose & wouldn't be close to fully engaging at normal freeway speeds/RPMs. Slippage creates heat which hurts trans life. Either way it would be a worthwhile investment to get a good trans cooler.
Re: alright, to you stall speed experts which speed with this cam and gears.... (Wrencher)
I had a cam that was 230/230 @ .050 .480/.480 My 3000 stall Hughes converter worked very well. I've had that cam behind 3.08's, 3.55's, and 4.11's. All ratio's worked well, but i'd say 4.11's were the best. I have an overdrive transmission with a lockup converter, so everythig calmed right down on the highway. The 3.08's were the only gears that wouldn't break the tires loose if you floored it at 25-30mph.
[Modified by Stingy74, 5:53 PM 2/26/2002]
Re: alright, to you stall speed experts which speed with this cam and gears.... (Stingy74)
Your stall converter should be rated for 1000rpms higher than where you cam comes in. So for example if you had a comp xe268 and it comes in at 1600, you could get away with a 2200-2400. This is just a rought guess and everyone I've talked to including Jegs and Comp Cams say's somewhere between 700-1000
