Brake problems
Brake problems
I have very little brakes pedal. I installe all new brake pad and bled all wheel cylinders. I have found no evidence of any brake fluid leakage. The brake pedal will not pump up, just goes all the way done to the stop. I bled the system again, twice. Still no brake pedal. Any ideas.
Thanks,
Thanks,
Re: Brake problems (Stickman)
Give us more info. Why were you working on the brakes? Was this happening before? Did it happen all of a sudden or over a period of time? Have you replaced and bled the M/C or did it run dry while you were working on the system?
