Anyone of pics of the inside parts of an engine?
I have to write a memo about a process for some stupid class. I and a couple other guys decided to do ours on "rebuilding an engine" (specifically a SBC). I was curious if you guys have engine pics? Like any one of them tore down any dirty... or any pics of internal parts that are screwed up would be great (like a good picture of a cylinder that needs to be machined or worn out pistons, crank, etc.)
I figure if I can find them anywhere, it would be here :yesnod:
thanks!
Brian
thanks!
Brian
Re: Anyone of pics of the inside parts of an engine? (Chris@VetteFinders)
Great! Some good one of the dirty stuff :yesnod:
If anyone else has some, please chime in :)
Re: Anyone of pics of the inside parts of an engine? (Brian-74-454)
Here is a couple of pics of my 454 if they are of any use. sounds like a fun project.
[Modified by 71vettman, 8:02 PM 2/25/2002] [IMG][/IMG]
[Modified by 71vettman, 8:03 PM 2/25/2002]
Re: Anyone of pics of the inside parts of an engine? (71vettman)
Vettman...I'm in awe! That's one of the most beautiful things I've ever seen.
Matt
Matt
Not sure if any of these will help you out but here's some from the rebuld of the engine for my project car.
http://home.hvc.rr.com/js34ford/34engine.htm
or
http://home.hvc.rr.com/joesvette/engine.htm
[Modified by 78Vette-SA, 9:25 PM 2/26/2002]
or
Platinum Supporting Dealership
Re: Anyone of pics of the inside parts of an engine? (78Vette-SA)
Joe, Why do you always refer to it as your "project car" and not a 34 Ford? That is some car you are building. :cool:
My page has some before and after pictures of my big block project. You can use them if you like. The URL for the page is in my signature.
But, it is a Chevy Engine (and Fiberglass for that matter) and much of the mechanicals apply so I don't mind posting a question once in a while to help move things along. By far, this is the best forum on the internet and that's because of the people here.
After a year and a half and some last minute setbacks I got to take the FORD out for a test drive this weekend. Didn't go far but what a blast. Once I get the final valve, carb and timing adjustments tweaked, it should kick pretty good for 2500lbs. I've got a few chassis (ride height) adjustments to make as a result of the test drive but other than that it was great.
Thanks!!!
I really don't think the people here care its a Ford. YOU are our friend, not the manufacturer of the car. :cheers:
I have some pics on my website that I took while I was building my engine. It's pretty much step-by-step for the most part.
http://www.montygwilliams.com/assembly.html
I have a number of images on my web pages. You're welcome to use them, but not for profit.
http://home.att.net/~ncarboni/NC82.html
Be sure and follow the underlined links in the text. You will find things like:
and
-Noel
and
-Noel
