Vacume valve inside air cleaner?
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
Oldtimer
Anybody know where I can get a replacement vacume valve the is inside the air cleaner? it controls the flapper in the two fresh air intakes on my 79 L-48?
Re: Vacume valve inside air cleaner? (killain)
That should be a common AC Delco part available at most auto stores. GM used the same one for years on most V-8's
Question - are you sure the vacuum valve is bad and not a frozen door? Put a vacuum pump to the input and see if the door opens, if not put vacuum to the door itself.
