Autocross Pictures
Autocross Pictures
Here are some pictures from the autocross event in Everett, Washington on 2-4-2002. It was a blast :)
[Modified by inqbus383, 12:05 AM 2/26/2002]
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Re: Autocross Pictures (Chris@VetteFinders)
Cool pics. How'd you take 'em? Don't see a passenger and can't see anything in the mirror.
Platinum Supporting Dealership
Re: Autocross Pictures (1LE)
Take a look at what appears to be under his car. Looks like a cone, but on closer inspection maybe that is one beside the car on the left? (Next to last picture)
[Modified by Chris@VetteFinders, 9:30 AM 2/26/2002]
I took the in car video with a small wireless camera mounted using 2 headliner screw holes, it is behind the t-top pillar. I actually ran novice class this time, next time I will probably have to run street tire.
Cruise-In V Veteran
Re: Autocross Pictures (inqbus383)
Thanks,
Avery
Re: Autocross Pictures (sharklover)
My brother got the wireless video camera with sound from http://www.x10.com. It actually was kinda complicated to get it all working. First there is the 4 AA battery powered camera that is mounted on an unused paint stirring stick(flat and about a foot long) that has 2 holes drilled that coincide with the headliner screws. The wireless reciever runs on 12 volts, so I just got a 6 amp hour battery (general purpose) and wired that up to power the reciever. The reciever then goes to a crappy old 8mm tape camcorder (battery powered) that has sound and video input via composite input(rca cord). Everything but the wireless camera I just put in the rear compartment. The x10 camera has a very directional antenna, so it didn't work to have the vcr in a different car. Surprisingly, all three sets of batteries lasted for the necessary amount of time to record everything, I turned everything off for the breaks. For simplicity's sake, I will probably try to get a good small and light camera that would be safe to attach with just a few screws.
[Modified by inqbus383, 3:50 AM 2/27/2002]
I have a helmet camera I use when dirt bike riding. I'll probably try it on the track next.
Here's a demo: http://coldfusiondemo.com/videos/Hill1.mpg http://coldfusiondemo.com/videos/Stream_Cross.mpg
[Modified by Chris@VetteFinders, 11:22 PM 2/26/2002]
