ELECTRICAL HELP NEEDED!!!
Old 02-25-2002, 06:52 PM
steelcities
steelcities's Avatar
Default ELECTRICAL HELP NEEDED!!!
I need help, seriously, I do. My car has not been run in about three months. Battery was dead. Tried to jump...nothing. Took it to NAPA, only getting about 300 cranking so I bought a new one. Got home, stuck it in. Put on the positive cable, went to hook up the negative and sparks went flying. Pulled it off and opened the hood. Smell of burnt rubber and smoke coming from pass. rear of the engine right below the plug wire. Looked around, couldn't see where it was coming from. Hooked up the neg and the pos on the battery and tried to turn it over. Nothing.
What boneheaded thing did I do wrong and what do I need to do to fix it?
P.S. Hate to come on here for simple stuff but I am in the middle of a master's program and have three very active kids so I am very limited on the time I can jack it up and go poking around. Thanks in advance.
Old 02-25-2002, 07:08 PM
hdpete98
hdpete98's Avatar
Default Re: ELECTRICAL HELP NEEDED!!! (steelcities)
the positive cable goes to your starter which is where you described the source of the smoke. check your starter and the connections. Be sure you connected the Positive cable to the Positive post of the battery.
Old 02-25-2002, 07:12 PM
Chuck Gongloff
Support Corvetteforum!
Chuck Gongloff's Avatar
Default Re: ELECTRICAL HELP NEEDED!!! (hdpete98)
The + cable, as well as the starter wiring harness AND all the fusible links are in the passengers rear area. Probably have one of the "hot" wires or the cable itself touching ground. You could have also fried the fusible links in the starter harness. If that's the case, you'll need to replace them. Hope this helps. Chuck
Old 02-25-2002, 07:23 PM
mrvette
mrvette's Avatar
the smell of burnt rubber...that is rubber specifically....is from the fuseible link in the wiring harness....it's rubber covered sometimes....
now if it's burning plastic, it's probably the wiring itself...you need to probably drop the starter motor, and find the short in the wiring...probably due to old age and lack of insulation....maybe the starter/bendix solenoid is at fault....
GENE
Old 02-25-2002, 07:27 PM
steelcities
Default Re: ELECTRICAL HELP NEEDED!!! (mrvette)
Thanks to everyone. Looks like I've got to find some time this weekend. :cheers:
Old 02-25-2002, 10:42 PM
LAvetteman
LAvetteman's Avatar
St. Jude Contributor
Be thankful the battery went dead, you may have had a fire there..
Old 02-26-2002, 11:28 AM
steelcities
Default Re: ELECTRICAL HELP NEEDED!!! (71,454,4spd)
:cheers: I'm not so sure that would be a bad thing. :lol:
To ELECTRICAL HELP NEEDED!!!
Quick Reply: ELECTRICAL HELP NEEDED!!!
