Brake bleeder valve sheered off, now what??
Trying to bleed the brakes and the left rear inside bleeder
valve sheered off. Can this be replaced? Can it be done
without opening the caliper?
Thanks for the help.
BTW, this is on a 1978.
Re: Brake bleeder valve sheered off, now what?? (TFeld78)
Had that happen about 6 months ago, tried to fix it, no luck, it just kept sucking air so I had to replace mine. :mad
Had the same problem. Here's some other suggestions/comments.
http://forums.corvetteforum.com/zerothread?id=217829
