1971 Lt-1 fan shroud part number?
Cruise-In VI Veteran
Cruise-In VII Veteran
Re: 1971 Lt-1 fan shroud part number? (sdixon)
Check over in correct restoration, some of the guys that hang out over there are walking encyclopedias of Corvette knowledge. I can't even give you the part number for a '69 LT-1, it isn't in the AIM.
The number I posted was from a parts book which is probably different than the original casting number. Maybe someone has a 71 AIM that would show the original casting number.
The correct part number is the one that Pete posted originally - 3956109. This number is also molded into the upper left corner of the shroud.
This shroud is the one listed in the parts book and was installed on every LT-1 I've ever owned including a '71.
It was still available under part number 3956109 as of six months ago for a list price of $139.00.
Regards,
Regards,
