Headers - How close is too close?
My Hooker SCs contacted my idler arm on the Pass side of my 427 (stock heads). I dimpled the pipes just a bit to make 'em clear. My question is, how close is too close? The dimple I added keeps the header clear of the idler arm now, but there's probably not more that 1/8" clearance. The headers have HPC coating in and out, but I'd still expect them to be pretty warm that close to the engine. I'm I gonna toast the idler arm and bushings?
I'm debating whether I keep the headers or ditch them for the stock manifolds again.
[Modified by 69L71, 6:02 PM 2/24/2002]
Re: Headers - How close is too close? (69L71)
69 had the same problem with mine,i later found out that the replacement idler arm i installed was a heavey duty version which is larger,i havn't decided what to do with mine but i sure don't want take a hammer to my hookers.hope this helps i know i was scratching my head for a while ... GENO
Re: Headers - How close is too close? (C-3 454)
For what it is worth if you read the documentation that comes with the headers Hooker claims that when you install there headers there will be a number of spots where the header will come extremely close to the chassis and other parts. They say "This is normal and you should not worry about it" This happens due to the tight areas that they had to work with in order to get the headers to fit. I don't know about you but that still does not make me feel very happy about it.
