"Beware" I Screwed Myself Don't You {help!!!}
I Took my Vette to the car wash today and as always washed the engine off
here's were i Screw Myself, I used the wheel creaner setting on the wash and
sprayed away. up until now i have always had chrome dress up and using the
wheel cleaner setting always shined it up nice, BUT NOW I HAVE POLISHED ALUMINUM you guessed it I am SCREWED :mad :cry :mad my brite work is
now gray and spotted :U :U :U :U :U
Re: "Beware" I Screwed Myself Don't You {help!!!} (mountainshark76)
Ouch - oye - bummer - eek! :boxing
If it makes you feel any better (it won't), on my project car I just finally got on the road I found out yesterday that the rear coil springs have to come back out because I cut them too short (coild and a half) and the bodies sitting too low. Bummer number one (about $65 so ok I can live with that). But, the Torq Thrust II's that I bought over a year ago for the car have the wrong backspace. They are 3 3/4" and because of the axles and disc brake combo I'm using I'm gonna need a 5" backspace. I had to order them special today for over $400. Big bummer... :mad :mad
So if anyone needs a brand new set of 15x7 TTII's, with 3 3/4" backspace and GM 4 3/4" lug pattern we can work it out.
I try to measure two or three times before cutting or buying something but yet it's always as if I bought/cut twice and measured once.
[Modified by 78Vette-SA, 4:26 PM 2/24/2002]
If you will take some aluminum wheel cleaner for the oncoated whells and spray it on the aluminum, then very quickly spray it off, ot might take some of the dark spots away. I use it on the plenum and runners on my 91.
Senior Member since 1492
Try some "Nevr Dull" aluminum wadding from Walmart. It got just about all of the dried coolant from my aluminum valve covers and all of the stains from my TTII's. It took a lot of rubbing, but I got most of the stains out! Happened when my upper radiator hose blew off the goose neck while driving. :eek:
thanks everyone i tried the never dull it helped, now every thing is evenly dull
the valve covers are the worst, do you guy's think they would come back if
i took them off and had them repolished :confused:
Re: "Beware" I Screwed Myself Don't You {help!!!} (bluevette)
How much for the TTII's?
John
John
Joe..
