Isn't it always the way?
You run out of pistons to install just when you get the hang of the ring compressor to where you can get the ringed piston in the bore on the first try every time. Welp, I guess I'll just run some numbers and pick the cam I'm going to order on Monday. There's this Lunati hydraulic roller that looks mighty attractive...
