march underdrive pulleys
has anyone tried using march under drive pulleys ? thinking about these and aluminum waterpump i'm replacing radiator didn't know if it would be creating more problems or if it would be a plus frankly i'll be doing good to get the radiator and shroud back in. also doing the headers and sidepipes. 69 350 mild mods. i need imput thanks
Re: march underdrive pulleys (laktrash)
laktrash,
I used the Marsh crank only underdrivepully on my 74. The other pulleys were left orignial. I have not had a problem with the alternator not charging at idle.I am using a Wieand Team G water pump which installed perfectly and has been trouble free.
Ed
Ed
Re: march underdrive pulleys (ED DINAPOLI)
I got the whole set with the exception of the PS pump. I had a few problems, but nothing major. I had to space the pulley behind the alt. and I spaced out the whole PS pump to align with the crank. I know that you will probably have to get a different part number for a 69, and there is a different number of grooves and may align more easily....Id say its worth it though, even for the looks!
I know there are a few other guys on the forum that have used them, so lets see whatt they have to say as well...
BTW, Welcome to the Forum!
Chris :cheers:
Chris :cheers:
Re: march underdrive pulleys (74VETTE)
I bought the set for the C3 Vettes, crank, WP, Alt but haven't put them on yet. Also have billet brackets for the AC, Alt, Ps with a PS pulley from Street & Performance. I won't know how it all works until next month when I get the new motor dropped in. All I can say is for what I spent this better work, it sure looks good so far.
I have a set on my car. I have some charging problems at idle but nothing I can't live with. Like another poster said, the looks alone are almost worth it.
Re: march underdrive pulleys (vett79)
Does anyone make stock size aluminum pulleys for C3's?
Street & Performance http://www.hotrodlane.cc/
March http://www.marchperf.com/
Summit http://www.summitracing.com/
JEGS http://www.jegs.com/
