Anyone polish the spindle bearing surface?
Old 02-21-2002, 09:31 AM
phoenix
Support Corvetteforum!
phoenix's Avatar
Default Anyone polish the spindle bearing surface?
I am reinstalling the front end and after taking a good close look at my two spindles... they are both in good shape, no divits or scratches on the bearing surfaces, but they look like they need to be polished (at least one does)
Should I do this, or am I looking for trouble?
Any recommendations?
Thanks :cheers:
Old 02-21-2002, 09:44 AM
gerry72
gerry72's Avatar
Default Re: Anyone polish the spindle bearing surface? (phoenix)
The spindle bearing surface only holds the bearing's inner roller guide. If the bearing assembly turns on the spindle, you've got a serious problem. It's just a machined surface and should not be touched.
Old 02-21-2002, 09:48 AM
SevenT1Shark
SevenT1Shark's Avatar
Default Re: Anyone polish the spindle bearing surface? (gerry72)
Just clean it up with a scotch brite pad and use a little grease when putting back together. :cool: :cheers: :seeya .........
Old 02-21-2002, 09:52 AM
phoenix
phoenix's Avatar
Default Re: Anyone polish the spindle bearing surface? (SevenT1Shark)
Thanks :cheers:
I won't mess with it then :)
To Anyone polish the spindle bearing surface?
Quick Reply: Anyone polish the spindle bearing surface?
