How do I remove headlight switch knob on a 73
Re: How do I remove headlight switch **** on a 73 (73-454)
There is a button on the side of the switch that must be pressed while pulling out on the shaft. This will release the shaft and ****. But getting to that button is a whole different story. Probably the best way is to raise the dash pad a bit to get your fingers into the switch area.
tom...
tom...
. . . nothing is easy on these C3's
Tom,
Thanks for the tip on the switch, my **** has broken and needs replaced.
