Starter Motor Gasket
While bench cleaning the oil and gooy stuff off my starter, pieces of a brownish fiber gasket/insulator looking material started falling out of the unit. I looked inside and could see all the wire windings of the motor. I haven't taken it apart, nor do I need to cause it works fine! Does this donut gasket/insulator seal the motor from the gear and shaft? Will it be OK to re-install starter without this seal?? :confused: :confused:
Re: Starter Motor Gasket (Silvr77)
I by no means am good with advice...but would this keep heat out ?
you know...from when people cant restart their vettes due to the heat of the engine and running for a while. Then when your engine cools the starter functions again....never happened to me....but I have read a lot of members experiencing this.
do you have a regular starter or mini-starter by the way? i heard mini's eliminate this dilemna.
as you know i am very qualified for
I justed removed my starter for the same reason. A good cleaning. Never saw any type of gasket material, but I would leave well enough alone. My starter looks like it is of the WW2 era its so old. I cleaned it, painted it and mounted it with a new solenoid. Worked just fine, and I can't imagine yours is in any worse shape. I also went to the local parts shop and got a heat shield for about $3.00. Painted it too and the whole assembly looks great. Now if I can just keep the oil leaks off it.
Regards,
Jim
Regards,
Jim
Re: Starter Motor Gasket (ylose)
The starter is the factory original. This gasket material (from what I could conclude) was a circular donut shape in the same diameter as the motor case, and stiff like insulator fiber. Many little dried up brittle pieces came out :confused: :confused: I thought it would be a winding insulator/gasket to keep oil and dirt out of the motor windings. If noone knows what exactly this stuff is... F*** it.. I'll throw it back in and hope for the best.
Thanks for your responses guys...
AHHEMM... Uhh, Ylose... their ain't no snow on my roof..cause there is way too hot a fire down stairs!! :jester :jester :jester
Re: Starter Motor Gasket (Jim73)
. Painted it too and the whole assembly looks great. Regards, Jim
Moderator
I've replaced a lot of chevy starters over my lifespan and I have never seen any type of gasket on one. Sounds like insulator materiel off your magnets or windings on the inside. I suppose you could just put it back in and use it 'til it fails but if it was me, I would change it. Starters are fairly cheap ya know, plus you don't got to paint a new one. :yesnod:
Silver on some of the older style starter motors that had a sheet metal dust cover over the openings near the brushes,, a gasket was used between the case and the dust cover .
G
I painted the starter red to match my body color. I also have already painted some of my engine bay red. I painted the new solenoid red also and the heat shield black. I also changed to external hardware to stainless steel although the oil leak keeps anything from rusting!
Regards,
Jim
Regards,
Jim
we definately gotta get together in spring.
:D :seeya
----note to self...silvr77 doesnt forget a post..even when server is down for over night! :jester
[Modified by ylose, 12:58 PM 2/20/2002]
[QUOTE] we definately gotta get together in spring.[QUOTE] OH YEAH!!!
Nope!........ But if I can only remember where I put that darn idler arm mounting bolt, and those pesky stove pipe hex... oh crap. Gotta sweep the floor and sift through the dirt :mad
-note to self...silvr77 doesnt forget a posT
