Big Block fouling plugs.:(
My 75 has a 454 from a 74 Suburban in it. I am running an Edelbrock cam, Torker II intake, and Performer carb as well as a stock 75 HEI distributor. I am running Hooker SC's and 2 1/2 true duals. At idle, the car loads up and the plugs are wet. The carb is right out of the box and has never been jetted. I am running R44TX plugs, is this causing me a problem or do I need to re-jet?
Re: Big Block fouling plugs.:( (Fastguy)
Sounds like timing or carb; is it the AFB style carb? what CFM is the carb? did you try setting carb mixture with a vacuum gauge? The correct mixture adjustments will show the most vacuum. Are you using manifold or ported vacuum? If ported, try manifold (direct) vacuum. I run 12-14 degrees initial advance, and use manifold vacuum for the advance mechanism. The plugs range seems plenty hot enough.
:chevy :chevy
:chevy :chevy
Re: Big Block fouling plugs.:( (MassVette)
I checked and re-checked my timing and tried ported and manifold vacuum. I am wondering if I am having a float issue. The carb sat for a while and there is an excelent chance that the the gas dried up and left a residue that is affecting the needle and seat.
It IS the AFB style which makes it a PITA to check float height unlike a Holley.
[Modified by Fastguy, 12:19 PM 2/20/2002]
These carbs can occasionaly have problems with the plastic shaft accelerator pumps, along with stuck needles and seats. When you remove the top, be careful not to lift too quickly. I broke the gasket in one of mine by being careless.
How long did the carb sit around? These are usually VERY good carbs. Maybe a rebuild kit would help...??
